Date/Time: Mon, 10 Mar 2025 16:22:28 +0000
Chart settings window format change with updated version
View Count: 527
[2022-04-03 15:08:40] |
User739946 - Posts: 3 |
Hi, I updated my SC to the latest version on friday and now when i hit f5 for the chart settings window, the blackscreen format appears (sorry not sure how to explain better...see screenshot) as opposed to the historic version. I couldnt find if this was a simple display setting change or how to revert it back or whether this is expected behaviour with this version ive update to v2376. Thanks I could not get the screen to screenshot using the preferred method so I attached it. |
[2022-04-03 16:39:12] |
Refer to the information in this post: What is Sierra Chart Working On | Post: 301755 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
