Date/Time: Mon, 10 Mar 2025 16:13:48 +0000
Service Connection Error
View Count: 491
[2022-04-03 12:55:49]
dubbs - Posts: 36
When I try to connect to datafeed I get a box that opens saying "Service Connection Error" on the top in the margin. The box has a narrow white/gray margin around the outer edges but the rest of the box inside the narrow outer white/gray margin is totally black and I can't see any text inside the black box. Why can't I connect to datafeed? It was working perfectly fine until Friday morning (2 days ago). I use AMP and CQG (order routing only) I use the sierra chart Denali data feed.
thanks
[2022-04-03 13:40:42]
Refer to:
Data/Trading Service Connection and Symbol Issues: 1.7. Unable to Connect Because Server is Not Available over the Weekend
And correct the Text Windows color settings so you can make the text visible:
Graphics Settings: Setting the Background Color, Text Color, and Font for Text Only Windows
[2022-04-04 01:52:43]
dubbs - Posts: 36
thank you
