Date/Time: Mon, 17 Mar 2025 18:17:48 +0000
Initial Balance - End Lines at RTH Session End (16:14:59)
View Count: 877
[2022-04-03 01:48:11] |
User688525 - Posts: 280 |
Hello Sierra, Is it possible with the Initial Balance study to end the lines at RTH Session End (16:14:59) so these do not carry through to Evening Session (16:15:00 - 09:30:00)? Thank you |
[2022-04-04 13:53:13] |
Yes this should be supported. Provide the chart with that study, by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-04 17:25:11] |
Hello Sierra, The chartbook has been attached. Note there are two studies: Initial Balance and Opening Range. These are the same with the difference being the lines drawn at 60 minutes for Initial Balance and 30 minutes for Opening Range. Thank you |
[2022-04-07 20:51:44] |
Hello Sierra, Any update on this? |
[2022-04-10 23:42:02] |
Sierra_Chart Engineering - Posts: 18809 |
We need more time to look at this to see how to implement what you require. Looks like we have to do additional implementation.
[2022-04-11 08:59:34] |
Ok, thank you.
[2022-09-11 19:52:57] |
User128517 - Posts: 10 |
Is there any updates on this? I was about to create a ticket on this but found this ticket instead. I am trying to plot IBs based on RTH and ETH. The extensions up carrying forward into the next session. Date Time Of Last Edit: 2022-09-11 19:54:16
[2022-09-13 07:41:37] |
There has been no development related to this yet.
[2022-09-14 07:34:46] |
binaryduke - Posts: 378 |
Use this built-in study. High/Low for Time Period - Extended |
