Date/Time: Mon, 10 Mar 2025 16:39:34 +0000
Disappearing Quote Board Window when Minimizing - Cannot Restore
View Count: 778
[2022-04-02 20:26:43]
User600202 - Posts: 37
SC version 2376 revision 41592
Win 7 Pro
On one of my Chartbooks, I created a Quote Board with symbols, modified fields, sequence, etc.
I clicked on minimize, that window went away but it has disappeared and I can find no way at all to restore it or get it back. This is not the first time it happens but this time I just cannot restore it. I am SURE I only clicked the "minus sign".
Any suggestions as to how to get it back/restore it and WHY this happens (rather frequently) would be appreciated.
And NO, it's not due to my OS, my OS setting for tasks in taskbar are set to ungroup so it is not bundled with SC task, etc.
Thanks for any helpful feedback.
[2022-04-02 21:29:54]
Refer to:
Getting Quotes: Quote Board Not Visible
If you want the Quote Board to appear on the taskbar, then detach it. You can do that through its Settings menu.
Date Time Of Last Edit: 2022-04-02 21:30:33
[2022-04-02 21:40:15]
Thanks for the feedback but 1) i cannot detach the quote board until it reappears. And even resetting the windows does not work, before or after closing and reopening chartbook....
[2022-04-03 00:15:48]
We have examined this problem, and definitely resetting the windows with Window >> Reset Windows will resolve the issue and make the Quote Board appear. If not, then there must be something operating system specific going on which we do not understand.
Date Time Of Last Edit: 2022-04-03 00:16:01
[2022-04-03 15:17:44]
I appreciate the feedback. There is nothing going on at the OS system, believe me.
I've "resolved" by creating a new chartbook and new quote board.
[2022-04-03 15:25:26]
Ok good.
