Date/Time: Mon, 10 Mar 2025 17:26:50 +0000
strage arrws behaviou
View Count: 530
[2022-04-02 15:50:54]
User427561 - Posts: 217
the arows in a bar study print sway below the viewing range of a chart excluding them from viewing during normal viewing of a chart. i tried all available adjustments availablet to no effect. can you explain this behavior and help in repositioning these arrows as usual,namely next to the candle where it happens?
[2022-04-04 14:23:40]
John - SC Support - Posts: 38542
What is the study for which you are having the issue?
[2022-04-05 20:10:56]
1mimute chart
[2022-04-05 23:37:32]
What is the study that you are using that is printing the arrows in the incorrect position?
