Date/Time: Mon, 10 Mar 2025 16:28:38 +0000
NASDAQ Pricing
View Count: 535
[2022-04-02 14:15:50] |
DabbaDo - Posts: 148 |
I thought the NASDAQ US Stock data cost $16 USD / month per Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes But when I go to the Activate page, it says $32 USD/Month --https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedNASDAQ Which is correct? Best regards, Dale |
[2022-04-02 20:04:58] |
This is because you would have activated two systems for the Denali Exchange Data Feed. So you only require this NASDAQ data on one system? That means we have to be able to control the number of systems per exchange group. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-02 20:08:41
[2022-04-02 21:55:07] |
Ah, I hadn't thought of that. Yes, I only need it on one system. But I can cut back to 1 system instead of 2 for Denali for now if necessary. Thank you. |
[2022-04-03 00:28:53] |
Yes go ahead and do that for now. Need to do this here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
