Date/Time: Mon, 10 Mar 2025 16:34:50 +0000
VbP - Multiple profile
View Count: 726
[2022-04-02 12:31:48] |
User738941 - Posts: 14 |
Hello, is there a way to separate only the last/current day profile when using multiple daily profiles so that its not overlapping the current price bars? I use the profile aligned to the right but its hard to see the bars as the day is developing. I have included my sierra screenshot and a screenshot of another platform to give an idea of what I mean in case I didnt describe well. Thanks in advance!
Date Time Of Last Edit: 2022-04-02 12:33:18
Private File Private File |
[2022-04-02 19:34:40] |
Refer to this section here: Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-03 17:10:10] |
So I have played with the lock screen and works for the far right profile (#2 in image). What I am trying to accomplish is so that the profile (#1 in image) to the left of the far right profile also provides a space between the last bar and the profile. Basically profile #1 is multiple daily profiles. The previous days profile is fine but I was hoping to provide a space just like you can with the lock space and the far right profile. Thanks!
[2022-04-03 17:13:40] |
If that profile is not set to be aligned to the far right, then it is going to overlap the bars. There is no support for what you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-03 17:22:00] |
Nevermind, I figured it out, thanks!
