Date/Time: Mon, 10 Mar 2025 16:42:25 +0000
Custom Calculated Values
View Count: 616
[2022-04-01 20:11:34]
User327376 - Posts: 13
I just started Denali package 12 and am having trouble setting the symbols for calculated values.
Attached is an image of message I get when adding {ESM22-CME}-{SPX500}
imageES-SPX500.png / V - Attached On 2022-04-01 20:11:04 UTC - Size: 15.93 KB - 140 views
[2022-04-01 20:24:47]
John - SC Support - Posts: 38537
Refer to the information here:
Custom Calculated Symbols: Resolving Missing Historical Data Issue
[2022-04-01 20:42:15]
The missing data suggestion didn't help, but I am now getting the FSE symbol.
another question I have is when using another symbol like GC-HG, would the symbol be {GCM22-COMEX}-{HGK22-COMEX} or replace COMEX with CME?
[2022-04-01 20:49:07]
You need to enter the symbols as they would be entered on a regular chart that you use. Therefore, if you change service settings, you would need to have a different set of Custom Calculated symbols.
Given this, make sure you have the symbols from the original post entered correctly for your current service.
[2022-04-01 20:55:25]
I am using Denali package 12. So the individual symbols show up as ESM22_FUT_CME, so for calculated symbols would it be {ESM22-FUT-CME}-{SPX500}?
Thanks for the Help John
[2022-04-01 21:12:15]
Yes, that is correct since you are using the Teton Order Routing Service.
[2022-04-01 21:22:03]
I got the same message. I must be missing something. I have Use Custom Symbol Setting Checked and Use Formula Operators checked to Yes, ut am still getting the same message. Attached
imageES-SPX500.png / V - Attached On 2022-04-01 21:21:19 UTC - Size: 7.68 KB - 124 views
[2022-04-01 21:36:54]
The symbols have underscores between the items (_) but you used a dash in the Custom Calculated Symbols. Make sure you enter the symbol as ESM22_FUT_CME
[2022-04-01 21:49:25]
That helped, now atleast I am getting candles, but still FSE.
I will play around over the weekend. Thanks again John.. much appreaciate your help
