Date/Time: Mon, 10 Mar 2025 14:39:45 +0000
cannot log into the program
View Count: 468
[2022-04-01 15:30:09] |
SINISA BUI - Posts: 1 |
I created an account yesterday, but I am unable to login to the program... Also, I would like to ask you if it is possible to trade through Interactive Brokers with your software once i have purchased it. Thank you in advance for your kind reply. |
[2022-04-01 16:34:34] |
We have activated your Sierra Chart account. Login to Sierra Chart using the same username you have logged into this Support Board with. Instructions: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name You also need to install Sierra Chart: Software Download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-01 19:00:35] |
John - SC Support - Posts: 38517 |
And yes, you can trade with Interactive Brokers. Refer to the Setup Instructions here: Interactive Brokers Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
