Date/Time: Mon, 10 Mar 2025 16:07:45 +0000
Hot key combinations will not function in the rest of Sierra.
View Count: 541
[2022-04-01 14:33:29] |
PapaSoma - Posts: 6 |
For example, I have a hotkey set to shift-m. If I want to change my symbol by typing it in, I can't use shift-m. It simply doesn't work. This is holding true for all hotkeys currently setup. I do not remember this occuring previously, but I also couldn't tell you exactly when this change happened. Thanks |
[2022-04-01 14:34:04] |
I have double checked this behavior with another Sierra user. He has the same issue.
[2022-04-01 19:05:26] |
stephenvosloo - Posts: 28 |
Plus 1 for this. I noticed that I have my trade quality set to numbers 1 - 5. When I’m in the updated menu system I can’t use those hot keys for regular number entry. So I usually just copy them from the text pad if I need to make a change.
[2022-04-01 20:02:22] |
John - SC Support - Posts: 38530 |
We have fixed an issue where if you were trying to type into one of the new Settings Windows and you happened to use a command that was setup as a Keyboard Shortcut, then the keyboard shortcut was occurring, not the typing. Although we were only able to reproduce the initial problem with a Detached window. First, update to the latest Pre-Release and see if you continue to have an issue. If you do, then please give us the specific steps you are taking to reproduce the problem. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-02 14:54:42] |
Resolved on my end with pre-release.
