Date/Time: Mon, 10 Mar 2025 14:17:14 +0000
List of conditions met on an intraday chart - How?
View Count: 430
[2022-04-01 14:03:27] |
dberliner - Posts: 16 |
I'm sure this is possible somehow, but I just couldn't figure out how. I have a particular Study that produces arrows when conditions met are TRUE on an intraday chart. I want to find all those instances in a combined list, instead of endlessly scrolling and manually hunting for them. How do I do this? I've tried searching for this in the scanning documentation but still can't figure this out. Thank you! |
[2022-04-01 17:52:56] |
John - SC Support - Posts: 38516 |
The only tool that has something akin to what you want is the Spreadsheet Study. It will include the study that produces the arrows, therefore you should be able to scan that information to see the true values fairly easily. Refer to the information here: Using the Spreadsheet Study: Step By Step Instructions to use the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
