Date/Time: Tue, 26 Nov 2024 06:40:37 +0000
Spreadsheet System For Trading issue
View Count: 987
[2014-04-22 23:02:21] |
vegasfoster - Posts: 444 |
FYI, in 1123, when I add a spreadsheet system for trading it is opening the default spreadsheet study instead. I have to manually select an old file to get a trading spreadsheet. I'm not sure if it is just on my end or not.
[2014-04-22 23:25:44] |
This makes sense. Unless you set the Spreadsheet Name it will be automatically set to DefaultSpreadsheetStudy.
