Date/Time: Fri, 11 Sep 2026 06:43:07 +0000
Reactivated Sierra Chart Exchange Data Feed and not getting real time stocks data now
View Count: 932
| [2022-04-01 13:23:37] |
| TradingPE - Posts: 7 |
Hi, I reactivated Sierra Chart Exchange Data Feed because it got deactivated and now I'm not getting real time stocks data. Please Help. I'm sure I have everything activated now...
| [2022-04-01 14:23:27] |
We will help you with this. Will have someone follow up with you. We prevent the reactivation or activation of the US Equities exchange through the Sierra Chart Exchange Data Feed because we have a new NASDAQ replacement data feed available: How to Use New NASDAQ Total View Data Feed But we can allow you to use the US equities feed. We just need to manually activate it for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-01 14:24:32
| [2022-04-01 14:26:52] |
| Jaydtrade - Posts: 123 |
I have a similar question. I activated the CME market depth 11 USD today. But it didn't ask me for any kind of payment information? Where does this get billed to then? My account balance on SC was at 0$ at the time of this.
| [2022-04-01 14:28:52] |
Ok thank you, if you could do that for this month I would greatly appreciate it... I'll try to get it squared away for the next month, thank you!
| [2022-04-01 14:43:07] |
| User587930 - Posts: 13 |
I have the same issue as the OP
| [2022-04-01 15:29:27] |
| voy - Posts: 14 |
I have the same issue! Please help. No real-time data on US Equities
Date Time Of Last Edit: 2022-04-01 15:30:15
| [2022-04-01 15:36:24] |
| User39653 - Posts: 13 |
I also have this issue. Created a ticket but don't see it on the board
| [2022-04-01 17:51:04] |
| SC Support - Posts: 2102 |
Connected with each User, helped with set-up
