Date/Time: Sun, 20 Sep 2026 08:48:43 +0000
How to set another symbol for another chartbook with same graph settings
View Count: 902
[2022-04-01 09:33:15]
Lowry BigEarth - Posts: 50
How to set another / 2nd symbol/ asset for another/ 2nd chartbook with same graph settings as the first.
Date Time Of Last Edit: 2022-04-01 09:34:35
[2022-04-01 17:27:12]
John - SC Support - Posts: 47939
The only way to do this is to duplicate the first chart and then change the symbol. Refer to the information for using a chart as a template here:
Using Chart Templates: Duplicating Charts / Template Charts
[2022-04-02 08:15:00]
Thnx, Did that ... seems I have to detach the duplicated charts from the "Global window" then it changes the symbol chart by chart = then all the charts are "loose" and have to see them one by one, which is complicated on 1 screen view.
In case to keep the duplicated CB attached to "global window" then symbol changes in both CB-s. How to make attached (not detached) CB-s (2 books) with different symbols!?
Thnx,
L.
Date Time Of Last Edit: 2022-04-02 08:31:15
imageSierra Support Same symbol in 2 chartbooks if attached 2 apr.png / V - Attached On 2022-04-02 08:31:10 UTC - Size: 83.44 KB - 256 views
[2022-04-04 10:56:29]
You will want to configure a chart as you require in a particular Chartbook, make sure it is attached and then duplicate that chart to the other Chartbook:
Chart Menu: Duplicate Chart To Chartbook (Chart menu)
You can then change the symbol to what you want. Instructions:
Changing the Symbol of a Chart
Date Time Of Last Edit: 2022-04-04 11:00:10
[2022-04-04 16:26:12]
In order to have attached charts within the Sierra Chart main window for different chartbooks, you would have to run a second instance of Sierra Chart and have that second instance open your "second" chartbook. Refer to the following:
File Menu: New Instance (File)
