Date/Time: Mon, 10 Mar 2025 17:27:47 +0000
Upgrading to full version - Data + Package question
View Count: 540
[2022-04-01 09:11:04] |
Connor Ballnger - Posts: 5 |
I will likely upgrade to the full package once my free trial has run out. I have a couple of questions first regarding the package and data options. The Dax, Bitcoin and the Bund are the markets I will be trading, possibly adding the Nasdaq. All in real-time with market depth. What Sierra package would be required, and what is recommended for the data? |
[2022-04-01 17:25:40] |
John - SC Support - Posts: 38542 |
In terms of the package, it depends on what you need for your trading. If you need the Advanced features like Numbers Bars and TPOs, then you would need the Advanced package, but if you do not use these, then you could use the Standard Package. Refer to the differences in the packages here: Description of Service Packages and Pricing: Packages In terms of data, we recommend using our Denali Exchange Data Feed, for which you will be on Package 10, 11, or 12 (again, depending on personal trading needs). For DAX and BUND, we assume you are wanting the EUREX exchange. This and the NASDAQ are available on the Denali Exchange Data Feed by following the setup instructions here: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* We are not sure which Bitcoin you are wanting, so if you give us some additional information on the particular exchange you are wanting, then we can point you in the proper direction. Also, if you are wanting data for CFDs rather than futures, then that data is available at no extra cost with any Sierra Chart package. Refer to the information here: Sierra Chart Real Time and Historical Forex and CFD Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-06 11:33:38] |
Thanks for the reply. I will be upgrading either today or tomorrow once I have sorted this data. I will be trading BTC/USD and possibly ETH/USD via the Binance or Bitmex feed. Will package 5 be sufficient for this? And what do I need to do to connect to the data feeds? Also, with package 5 is the FXCM forex data included or is the denali package required? Thanks |
[2022-04-06 12:06:11] |
Yes Service Package 5 is sufficient for what you require. And yes the FXCM data is included. Regarding using crypto currency market data, refer to: Cryptocurrency / Bitcoin Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
