Date/Time: Mon, 10 Mar 2025 14:13:34 +0000
Delta Volume Bars did not work today 3/31/2002
View Count: 422
[2022-04-01 02:00:23] |
User297050 - Posts: 51 |
Today all I have is one long bar for the "Delta Volume" chart bars no matter what value I insert in the chart specs. Is this a temporary known problem with SC? Prior days look fine in the same chart.
[2022-04-01 16:59:11] |
John - SC Support - Posts: 38516 |
This would be the case for any historical data that was downloaded, but you should be fine with any real-time data that is coming in while you are connected to your CQG account. Refer to the second bullet point at the following link for why historical CQG data is not going to have the Ask/Bid information: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2351 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
