Date/Time: Mon, 10 Mar 2025 14:29:38 +0000
Rithhmic Servers not Showing
View Count: 415
[2022-03-31 21:13:14]
DianaPena - Posts: 33
Would you happen to know why the servers for Rithmic are not showing in the dropdown?
Thanks!
imageservers.png / V - Attached On 2022-03-31 21:12:52 UTC - Size: 27.04 KB - 129 views
[2022-03-31 21:21:51]
John - SC Support - Posts: 38517
After you select the Rithmic Diret - DTC for the Current Selected Service, you need to then select OK to close that window and then wait 10 seconds and then open it again and the list of servers should be populated. Refer to the instructions at Step #9 here:
Rithmic Trading Platform Service: Setup Instructions
[2022-03-31 21:48:05]
Oh wow Sorry. I totally skipped step 9. Thank you John.
