Date/Time: Mon, 10 Mar 2025 14:33:39 +0000
Treasury symbol
View Count: 780
[2022-03-31 19:48:14] |
Irish Brian - Posts: 5 |
Hi, I don't seem to be able to find the symbol for ZN & ZB treasuries. ZBM22-FUT-CME seems to be working for some people but I have tried many different variants and they don't seem to work. I can't find them in my list of available symbols either, 10 treasuries seem to be F.US.TYAM22 on my symbol list and 30 years seem to be F.US.USAM22, is this correct or should they begin with ZN & ZB. Thanks
[2022-03-31 20:56:10] |
John - SC Support - Posts: 38517 |
Each company uses a different set of symbols for the particular instruments they make available. We take care of the translation of these symbols in our Find Symbol page. So you would want to search for your particular treasury futures on the File >> Find Symbol page, just be sure to look at the description and not the symbol name, as CQG, in particular, often uses symbols that are in no way relatable to the actual exchange symbol used. You can also look through the list of CQG symbols at the following page: https://www.cqg.com/partners/exchanges/tradable-symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
