Date/Time: Mon, 10 Mar 2025 14:04:49 +0000
problem update
View Count: 409
[2022-03-31 15:19:41] |
Flamini Jean-Claude - Posts: 2 |
Good morning, I have a problem out of the installation updates of the current version the messages " installation complete with errors " is displayed. Do you know how to solve the problem? Thank you in advance. best regards. |
[2022-03-31 15:22:06] |
Possibly this can be safely disregarded. We want you to install Sierra Chart again using this up-to-date installer: https://download2.sierrachart.com/downloads/SierraChartFileDownloader.exe Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
