Date/Time: Fri, 25 Sep 2026 22:51:19 +0000
create list/spreadsheet of actual study input values
View Count: 733
| [2022-03-31 14:27:43] |
| User917344 - Posts: 1 |
Is there a way to create a list of all my setting input values for a particular study? Ideally I'd like to create an excel spreadsheet with tabs for each of my studies for a particular chart. I'd like each tab to to have two columns of data. The first column would show input names for the study. The second column would show current input values for each input name. Thanks in advance for you help.
| [2022-03-31 17:54:52] |
| John - SC Support - Posts: 48028 |
You would have to create a custom study to do this. Refer to the GetChartStudyInput functions starting here: ACSIL Interface Members - Functions: sc.GetChartStudyInputInt() Just so you are aware, you can define the default values that you want a study to use. Refer to the following: Chart Studies: Using Custom Default Study Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
