Date/Time: Mon, 10 Mar 2025 14:15:18 +0000
kEYBOARD SHORTCUTS NOT WORKING IN 2ND INSTANCE
View Count: 679
[2022-03-31 11:51:09] |
Yeager - Posts: 131 |
On my 2nd instance of 2372 build, I have the same keyboards shortcut files and can see they same shortcuts as my main instance are present. However only some work in the 2nd instance? The ones that do not work I can see are assigned in 2nd instance. Thanks Date Time Of Last Edit: 2022-03-31 11:52:04
[2022-03-31 12:43:59] |
Refer to: Global Settings Menu: Keyboard Shortcuts Not Functioning We really cannot provide help beyond this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-01 13:47:11] |
Unfortunately with Keyboard shortcuts turned on, still not getting shortcuts to work. Only about 5% of them do work. Its very strange.
