Date/Time: Mon, 10 Mar 2025 14:12:17 +0000
[Programming Help] - HELP! NEED SPREADSHEET FORMULA FOR A CROSSOVER SPREADSHEET SYSTEM!
View Count: 426
[2022-03-31 09:53:13] |
User9890731 - Posts: 47 |
HI, I need a formula for K-3 and M-3 respectively for a simple crossover spreadsheet that am running. I tried using the sierrachart ''Trading System study crossover'' but it seems to have a hard time keeping up with the signals and it tends to get confused when multiple signals are generated over a short period of time. The crossover is basically between a moving average and cumulative delta study, nothing complex. When the cumulative line is over the moving average then a buy entry should be initiated and vice versa. I have attached the spreadsheet cells for reference. thanks in advance |
