Date/Time: Mon, 10 Mar 2025 13:30:48 +0000
Pulling / Stacking data from DOM
View Count: 1583
[2022-03-30 15:54:07] |
User327376 - Posts: 13 |
Is it possible to have this data show as a candlestick on a chart? Thank you |
[2022-03-30 17:21:08] |
John - SC Support - Posts: 38516 |
There is some ability to do this. In particular, the Numbers Bars Calculated Values 2 has the following 3 Pulling/Stacking items: - Sum Bid Pull/Stack - Sum Ask Pull/Stack - Ask/Bid Pull/Stack Sum Diff Therefore, if you are wanting to use any of these, then you could use the Spreadsheet Formula (Bar) to define the various parts of the Candlestick with each of these items. Refer to the following for the Numbers Bars Calculated Values studies: Numbers Bars: Displaying Numeric Information Below Numbers Bars And refer to the following for the Spreadsheet Formula (Bar) study: Spreadsheet Formula For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-30 17:39:12] |
Also pulling and stacking data is not accurate with Transact data. You must use the Denali Exchange Data Feed: Denali Exchange Data Feed And refer to the prior post as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-31 14:09:29
