Date/Time: Tue, 26 Nov 2024 09:40:08 +0000
Quote Board Data
View Count: 1042
[2014-04-22 15:43:07]
ZH Support - Posts: 19
Sierra,
I was wondering if there is a reason on the quote board some the market stats don't update in certain fields. I have done it on my AT chart version 1102 and its working but on 1123 it shows up as below?
Anything you can do to help. Thank You
Jake
image2014-04-22_1030.png / V - Attached On 2014-04-22 15:42:50 UTC - Size: 28.76 KB - 365 views
[2014-04-23 02:09:54]
The Daily Change and Daily Change Percent are 0 for market statistics. They are not considered valid and remain at 0.
[2014-04-23 12:50:41]
User17007 - Posts: 7
I'm getting Daily Change (and percent) as 0 for futures contracts as well...
Thanks!
B
[2014-04-23 16:45:22]
What Data or Trading service are you using Sierra Chart with? Give us the exact symbol.
[2014-04-24 13:16:09]
I recently switched from ILQ to ADVANTAGE ... so I'm using CQG ... I get zeroes for all symbols but one in particular is #F.US.CLEM14
Also, how do I get spread contracts with this new service? I used to get them with ILQ/Velocity where I think they were using the TT feed.
Thanks!
[2014-04-25 03:01:59]
Get zeros for what?
Spreads are not currently supported with CQG.
