Date/Time: Fri, 07 Feb 2025 15:02:21 +0000
Renko Study help!
View Count: 542
[2022-03-30 03:45:31] |
Jaydtrade - Posts: 88 |
I have moved my charts from Tradovate over to SC. Enjoying the learning curve :). I use a Renko 14 tick Momentum Range candle there. All I see is tick I dont see Momentum range as an option. It has some kind of build in code that will put white/pink candles in times of high movement that can retrack or print into green or red depending on direction. Once they print they dont erase but while in white/pink they can retract, sometimes its 1 2 or 3 depending on strength. But to my point can someone point me to how I may set this up here on SC? Other than telling me to search Renko which I've done and read everything on this website with it and did not give me what I am trying to build here. Thank you!
Date Time Of Last Edit: 2022-03-30 03:54:39
[2022-03-30 15:16:07] |
John - SC Support - Posts: 37808 |
The built-in Renko functions do not have what you are looking for. The only thing we can think to try is the Color Bar Based on Alert Condition study to see if you can create an alert that will color the bar White/Pink. We are not sure of exactly your criteria, but it sounds like you just want this for the most current bar, therefore you would set the "Number of Bars to Calculate" to "1". Refer to the information at the following link for the Color Bar Based on Alert Condition study: Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
