Date/Time: Mon, 10 Mar 2025 13:32:22 +0000
Study to compare bid volume across bars at the extremes of each bar
View Count: 428
[2022-03-30 00:01:24] |
cubicbalance - Posts: 1 |
I would like to ask if there's a study that allows me to compare if in the lowest tick of the numbers bar, the bid volume is lower than the bid volume in the next tick, and so on and so forth. Hopefully I can highlight when there is such an occurence. In the attached picture, this means that this study will show there are 5 consecutive ticks where the bid volume gets progressively lower: 676, 393, 243, 181, 16 |
[2022-03-30 14:41:03] |
John - SC Support - Posts: 38516 |
You can use the Spreadsheet Formula to do this. We have put together a Study Collection that tests the bottom two Bid Values and gives you a yellow square at the low when the lowest bid is lower than the next bid above it. You can expand this to do what you need. Refer to the following for how to use a Study Collection provided by Support: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
