Date/Time: Tue, 26 Nov 2024 06:53:24 +0000
SR zone coloring
View Count: 1234
[2014-04-22 13:28:13]
User30743 - Posts: 365
hello,
a very simple tast to do, yet i still havent figured out how to do it.
could you please advise me how i colour the sr zone between two horizontal lines that i draw into a chart - as it is on this screenshot (ps. this is not my personal screen, i have found it on the web, without explaining how to color the zone :-(( ).
imageES-2012-06-05-vyhodnoceni.jpg / V - Attached On 2014-04-22 13:28:09 UTC - Size: 220.56 KB - 414 views
[2014-04-22 15:17:07]
Refer to the documentation for this here:
http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#FillingArea
This can be done by using the Horizontal Lines study.
[2014-04-22 19:59:47]
sorry, but this is not what i meant - i dont need Filling the Area Between Two Study Subgraphs because i dont use any studies (so there are no subgraphs).
i use just horizontal lines from tools and want to color the area between two particular lines. nothing special
[2014-04-22 20:15:47]
Profile Trader - Posts: 174
Try using the "extending rectangle" instead of lines and then you will have several different options for the fill of the rectangle..
Doug
[2014-04-23 09:35:31]
cool, this works, thanx
