Date/Time: Mon, 10 Mar 2025 14:15:48 +0000
Exchange Fees
View Count: 470
[2022-03-29 15:28:16] |
LucentTrader - Posts: 35 |
I currently subscribe to Full CME with Market Depth for $33/mo. I do not use Market Depth. There is an alternative Full CME without Market Depth for $3.50/mo. I do not use the Market Depth study. Will the subscription without Market Depth supply the data for the Numbers Bars study and enable me to trade the CME products as I do now?
[2022-03-29 16:06:40] |
John - SC Support - Posts: 38516 |
We think so, as the Market Depth is not needed for the Numbers Bars study. Keep in mind the Market Depth shows all the limit orders on the exchange, so that gives you the listing in the DOM of the numbers up and down the price ladder. If you do not use that information for anything, then you would not need the Market Depth. Since we are close to the end of the month, if you want to make this change, then do the following: - Today, go to the following page and select the Deactivate button for your current exchange (you will continue to get the data through the end of the month): https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges - On April 1, 2022 when you get started in the morning, go the same page again and select the Activate button for the exchange you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
