Date/Time: Mon, 10 Mar 2025 13:25:58 +0000
log in
View Count: 1139
[2022-03-29 15:25:11] |
User206135 - Posts: 2 |
my sierra chart software is not showing no charts, even that i put enough money in the account for the service, it is saying that the password and username are wrong but i made sure it was not. it also says sevice will be renew in 54 days now that i press activate now, everytime i do dates get farther and farther away, thanks
[2022-03-29 15:57:36] |
John - SC Support - Posts: 38516 |
Where exactly are you getting the message about an incorrect Username and Password and what exactly is the message?
[2022-03-29 18:40:56] |
in the first window to open the application , on the dashboard of my computer, as soon as i want to open the application, i click the icon, program opens and loads, log in goes straight because my username and password are recorded and then programm opens but is not connected and soon after a second window opens saying i have incorrect username or password , but then it does not make sense since i go to help, data trade services and connects to my accout. after logging the next message is this , connection error message from device, cqg webapi, logon unsuccesfull, server message, username or password incorrect date and time thanks |
[2022-03-29 19:16:36] |
For help with this, refer to #5: CQG Trading Platform Service: Common Error Messages Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
