Date/Time: Mon, 10 Mar 2025 14:28:26 +0000
text is too small
View Count: 432
[2022-03-29 15:23:35]
User977139 - Posts: 2
I wish to use your Telephone/paid support.
I have an issue with the very small text in the platform and in the settings.
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=62874
[2022-03-29 15:50:59]
John - SC Support - Posts: 38517
Follow these instructions:
- Select Global Settings >> Graphics Settings - Global.
- Select the Fonts tab.
- Scroll to the bottom of the list and select the entry for Settings Windows (it will list the selected font after the name, do not worry about that).
- Select the Select button at the bottom of the screen.
- Select an appropriate font size (typically 10-12, but depends on your particular monitor and preferences) in the Size section on the right.
- Select OK.
- Select OK.
- Open a Settings window and see if the font is what you want. Repeat above as necessary to change the font to a size of your liking.
