Date/Time: Mon, 10 Mar 2025 13:05:36 +0000
Changing Candle Wick Colors
View Count: 1814
[2022-03-29 07:14:29]
RHudson85 - Posts: 33
I am attempting to change the color of the candlestick wicks, but this option is completely grayed out (see attached pic). How do I make it so that it is not grayed out so I can make changes. Thank you.
imageCapture.JPG / V - Attached On 2022-03-29 07:10:46 UTC - Size: 65.85 KB - 258 views
[2022-03-29 13:51:18]
Select the "Colors and Widths" tab.
Also make sure you are using the right Settings window:
Graphics Settings: Introduction
[2022-03-30 06:50:47]
I was under chart settings and needed to go under global settings. Thank you very much!
