Date/Time: Mon, 10 Mar 2025 14:00:23 +0000
F.US.BTCH22 not rolling over?
View Count: 499
[2022-03-29 05:46:02]
user8888 - Posts: 159
I don't know the rollover dates, but I know there is too little volume in the H contract, and much more in the J, but does not roll over.
but also seems to be some sort of problem with the J contract.
If I'm not mistaken.
Thank you
[2022-03-29 14:06:41]
John - SC Support - Posts: 38516
The default setting for the rollover of BTC is the Last Thursday of the Contract Month. If you have the option for Global Settings >> General Settings >> Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume, then it will do the rollover based on the volume. Refer to the following:
General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol)
Also note that you can change the rollover date by entering additional days for Global Settings >> General Settings >> Additional Days to Add to Rollover Date for Automatic Chart and Quote Board Rollovers. Refer to the information here:
That all said, it will not rollover automatically unless you have the option to do so set in Chart Settings >> Automatically Rollover Futures Symbol. Refer to the following:
Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu)
If you want to manually rollover you can select Chart >> Perform Futures Symbol Rollover and select the contract you want. Refer to the following:
Chart Menu: Perform Futures Symbol Rollover (Chart menu)
We do not see anything particularly odd about the J contract for BTC. It just appears that this is not traded a lot.
Date Time Of Last Edit: 2022-03-29 14:07:01
[2022-03-29 16:12:34]
Thank you.
Yes, I have the "Automatically Rollover Futures Symbol" chart setting enabled.
I'll check again.
BTW, reading your answer from the tablet, I clicked, by mistake, the "set" button. I can't find and 'unset' button so this post became an 'user discussion'.
by mistake.
Sorry about that.
