Date/Time: Sun, 27 Sep 2026 11:04:46 +0000
Historical Daily Charts Not Working for MBT and MET
View Count: 920
| [2022-03-29 00:56:01] |
| fykemang - Posts: 49 |
The historical daily charts for MBT and MET are stuck to last Friday. It looks like the same is occurring for intraday charts. https://www.sierrachart.com/image.php?Image=1648515310142.png |
| [2022-03-29 07:48:04] |
This is no bug. Contact the exchange, for their expiration rules.
| [2022-03-29 15:33:29] |
Why do I have to manually rollover? I have automatically rollover set to true with volume based rollover. What else do I need to do to get the contract to roll over automatically?
| [2022-03-31 18:53:54] |
| Sierra_Chart Engineering - Posts: 24983 |
This option does not provide an automatic rollover. It just gives a notice on the chart and then when you left click on it you can then roll over: General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) Although actually we think you are referring to this option: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-31 18:54:45
