Date/Time: Mon, 10 Mar 2025 14:28:15 +0000
[User Discussion] - error stocrossover 1 mt chart.
View Count: 482
[2022-03-28 18:02:01] |
User427561 - Posts: 217 |
I chose the crossovr sto on my 1mt chart as usual,and the down arrow only seems active on my chart. the up arrow does notprint, any suggestion?
[2022-03-28 19:15:28] |
John - SC Support - Posts: 38517 |
We are not seeing any issues with the Stochastic Crossover System Study. But, there has been a large uptrend for approximately the past 3 hours on the major indices, which will tend to generate mostly Sell signals from that study. It sounds like this is all you are seeing. Look back to last night and see if you have the Green Arrows showing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-28 20:27:24] |
going back does not show same signals an works ok but going back to your rsponse,I brg to disagree,even if the narket is up stongg,it does do it in a straight line deni=ying thefluctuating opposit signals to appear.i.e regardless of stong market either way the up and down signals should register thedovkasicsshould regisrer the fluctuationin in she trend on the chart. please correct me if my interpretation is wrogng thanks Date Time Of Last Edit: 2022-03-31 15:37:45
