Date/Time: Tue, 26 Nov 2024 06:54:33 +0000
[User Discussion] - Request : H or L, N bars ago
View Count: 1066
[2014-04-22 12:27:49] |
NRGTrader - Posts: 351 |
I want to plot certain values, e.g., the High or Low, for x bars ago, e.g, 3 days ago. I want the value plotted on the current bar, e.g., day.
[2014-04-23 11:08:16] |
[2014-04-23 17:17:53] |
You can do this but not based upon bars but Days and other time periods. Use the Previous OHLC-Variable Period study. We did previously answer this question for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-23 17:42:36] |
Yes, I saw you answered, but that doesn't provide the results I want. Example, if I want "x" to be 5. I would like to plot the H and L from 5 days ago on today; Going back in time, the H and L plotted on yesterday's "bar" would be from 6 days ago from today. Forward in time, the H and low from 4 days ago would be plotted in the future tomorrow, 1 day; from 3 days ago, the day after tomorrow, 2 days. The result would be a H line and a low line of "points" on each day from 5 days in the past and projected from today 5 days in the future. |
[2014-04-23 17:52:31] |
You will need to custom program this. We cannot provide further help on this.
[2014-04-23 18:00:27] |
Private email me please -
[2014-04-23 18:08:40] |
We are not going to do that. What is your question? We do not provide custom programming services and if you need help, refer to: https://www.sierrachart.com/index.php?l=doc/SierraChartStudyAndSystemProgrammers.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-23 18:10:27] |
OK. I guess you have changed your policy since you did do a small project for me in the past.
