Date/Time: Mon, 10 Mar 2025 14:29:38 +0000
monthly connection to get eraltime data
View Count: 671
[2022-03-28 17:48:29]
Don H - Posts: 31
Not sure how to renew monthly connection to keep real time data with cme. Have an AMP futures account.
[2022-03-28 18:54:23]
Follow the instructions here:
AMP uses CQG, so you need to go through these particular set up instructions during the steps linked above:
CQG Trading Platform Service: Setup Instructions
[2022-03-31 17:49:22]
Don H - Posts: 31
pressed disconnect and then to data/trade where I switched to cqg in data settings then switched back and reconnected to SC all services with connect to data feed but realtime connection does happen- message reading |
connection error message from CQG Web/Logon unsuccessful. Server message.Username or password is incorrect.
Not sure what to do
[2022-03-31 18:11:51]
John - SC Support - Posts: 38517
The Username or Password you entered for CQG were incorrect. Try entering them again and if you continue to get the same message then you would need to check with your broker to see about changing the password.
[2022-03-31 18:27:36]
Refer to 5 here:
CQG Trading Platform Service: Common Error Messages
