Date/Time: Mon, 10 Mar 2025 14:28:15 +0000
trade log time incorrect
View Count: 997
[2022-03-28 15:21:54]
jakeybleez - Posts: 56
hi when i exported my trades and uploaded them to my journal i noticed that the time is off, it appears the trade activity log is about 5 hours ahead, it is saying my trades are happening on 3/28 already.
any idea where the settings for this would be? thank you so much
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=62844
[2022-03-28 17:16:08]
John - SC Support - Posts: 38517
When you "export" the Trade Activity Log the times are in UTC. This allows for the reimport of the data, if you need to.
If you instead select "Save", then the times will be in the time of the chart.
Refer to the information here:
Trade Activity Log: Importing and Exporting Data
And here:
Trade Activity Log: Saving the Log
