Date/Time: Mon, 21 Sep 2026 01:37:03 +0000
Rithmic and Trade Evaluation Programs
View Count: 2968
| [2022-03-28 15:21:32] |
| User240686 - Posts: 86 |
I have used sierra in the past and loved it but then rithmic stopped working with Sierra so was forced to find another platform. Do you now support multiple rithmic accounts from either the same eval program, be it Leeloo, Apex etc and also is it possible to copy trades from one account to another. I am aware you can login different instances so does that mean you could log in Apex, Leeloo and any other instance and copy trades across all? Can you please advise on limitations etc. thank you ever so much
| [2022-03-28 15:23:13] |
| binaryduke - Posts: 387 |
This webinar from a couple of weeks ago should help you! Addresses everything you've asked: https://youtu.be/bk4WZiH-K0k |
| [2022-03-28 17:29:23] |
| John - SC Support - Posts: 47939 |
There has never been a limitation on the number of Rithmic connections you can make in Sierra Chart. The best way to do this is to have separate Sierra Chart installations for different connections. Refer to: Using Multiple Data and Trading Services at the Same Time With regards to copying trades, you can only do this when you have multiple accounts with the same entity, such that when you login to that entity your multiple trading accounts are pulled into Sierra Chart. Refer to the following: Order Allocation to Trade Accounts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-28 18:32:17
| [2022-04-01 01:26:08] |
is there a way for me to test before committing to the platform again with rithmic feed from Leeloo etc?
| [2022-04-01 08:54:56] |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-04-01 09:53:23] |
i get a message to say Rithmic is not enabled on data package
| [2022-04-01 09:59:17] |
i am also not sure of any user login and password information for Sierra. I only know my Leeloo and Bulenox login credentials
| [2022-04-01 18:51:38] |
I can open Sierra and it tries to connect to my rithmic leeloo account but fails to do so. Thanks for extending use for me to test but I can’t test if I cannot log in
| [2022-04-01 19:05:41] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-04-01 21:43:41] |
| Sierra_Chart Engineering - Posts: 24905 |
Regarding Post #6. This is resolved for your account. We changed the Service Package to 11.
| [2022-04-01 23:08:41] |
Reading Internal Order ID file. | 2022-04-01 19:06:35.788 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2022-04-01 19:06:35.893 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 32768 | 2022-04-01 19:06:35.893 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2022-04-01 19:06:35.893 Reading Trade Orders file. | 2022-04-01 19:06:35.930 Reading Trade Positions file. | 2022-04-01 19:06:35.947 Reading Trade Account Data files. | 2022-04-01 19:06:35.947 UDPListener (1548). Port 22903 | Listening on UDP port 22903. | 2022-04-01 19:06:35.970 Software version: 2376 64-bit | 2022-04-01 19:06:35.970 Primary Thread ID: 9644 | 2022-04-01 19:06:35.970 Usage end date: 2022-04-16 | 2022-04-01 19:06:35.970 Enabled for: Advanced Features 2. | 2022-04-01 19:06:35.970 Enabled for: Sierra Chart Historical Data Service. | 2022-04-01 19:06:35.970 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-04-01 19:06:35.970 Enabled for: Delayed Denali Exchange Data Feed. | 2022-04-01 19:06:35.970 Enabled for exchange2: fairx_exchange.data | 2022-04-01 19:06:35.970 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-04-01 19:06:35.970 Current selected Data/Trading service: Rithmic Direct - DTC | 2022-04-01 19:06:35.970 Custom symbol settings values: disabled | 2022-04-01 19:06:35.970 Chart Update Interval: 10 | 2022-04-01 19:06:35.970 Intraday Data Storage Time Unit: 0 | 2022-04-01 19:06:35.970 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-04-01 19:06:35.970 2022-04-01 23:06:35 Local computer time in UTC | 2022-04-01 19:06:35.970 2022-04-01 19:06:35 Local computer time in SC Time Zone | 2022-04-01 19:06:35.970 2022-04-01 23:06:35 Server time in UTC | 2022-04-01 19:06:35.970 Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-04-01 19:06:35.970 Program path: D:\SierraChart\ | 2022-04-01 19:06:35.970 Data Files path: D:\SierraChart\Data\ | 2022-04-01 19:06:35.970 OS Version Number: 10.0 | 2022-04-01 19:06:35.970 Locale Setting: C | 2022-04-01 19:06:35.970 DLLs: amirN.dll, BetterRenko.dll, futuresfx-drl.dll, futuresfx-sc.dll, futuresfx-sc_64.dll, MurreyMathv1.0.dll, mycrossoverdll.dll, PTFStudiesV1.dll, SAL.dll, SAL_2151_64.dll, SAL_64.dll, TicinoMathV2.0.dll, TicinoMathV2.0_64.dll, TTIDRL_DEC_2020_64.dll, tti_alert.dll, tti_alert_2151_64.dll, tti_alert_64.dll, tti_drl.dll, tti_drl_2151_64.dll, tti_drl_64.dll, tti_reversals.dll, tti_reversals_2151_64.dll, tti_reversals_64.dll, tti_volume_profile.dll, tti_volume_profile_2151_64.dll, tti_volume_profile_64.dll, UserContributedStudies.dll | 2022-04-01 19:06:35.971 Allowed protected custom studies: futuresfx-drl, futuresfx-sc | 2022-04-01 19:06:35.971 Crash reporter started: true | 2022-04-01 19:06:35.971 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2022-04-01 19:06:35.992 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:06:36.030 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-04-01 19:06:36.273 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-04-01 19:06:36.273 Received 5 login tokens. | 2022-04-01 19:06:36.752 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2022-04-01 19:06:37.001 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2022-04-01 19:06:37.002 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-04-01 19:06:37.002 HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2022-04-01 19:06:37.002 Symbol settings MD5 received. Request ID: 1. | 2022-04-01 19:06:38.182 Requested symbol settings for service code rithmic_v2.trading. Request ID: 2. | 2022-04-01 19:06:38.182 Files to Open on Startup | Opening file: 01.Cht | 2022-04-01 19:06:41.145 The Chartbook file is not a valid Chartbook. File: D:\SierraChart\Data\01.Cht | 2022-04-01 19:06:41.195 * Files to Open on Startup | Opening file: 01RTY.Cht | 2022-04-01 19:06:41.195 The Chartbook file is not a valid Chartbook. File: D:\SierraChart\Data\01RTY.Cht | 2022-04-01 19:06:41.211 * Files to Open on Startup | Opening file: 2TPRO.cht | 2022-04-01 19:06:41.211 The Chartbook file is not a valid Chartbook. File: D:\SierraChart\Data\2TPRO.cht | 2022-04-01 19:06:41.228 * Symbol settings received. Request ID: 2. | 2022-04-01 19:06:41.236 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:06:43.234 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:06:43.236 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:06:43.651 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:06:43.651 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:06:43.651 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:06:43.897 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:06:43.897 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:06:43.897 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:06:43.897 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:06:44.646 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:06:44.646 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:06:44.646 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:06:44.646 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:06:44.646 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:06:44.646 WSACleanup called. | 2022-04-01 19:06:44.678 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:06:44.678 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:06:44.679 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:06:44.679 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:06:44.679 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:06:44.679 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:06:44.923 DTC Client socket (1) | Closed. | 2022-04-01 19:06:44.923 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:06:48.683 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:06:48.684 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:06:48.684 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:06:48.684 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:06:48.684 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:06:48.932 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:06:48.932 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:06:48.932 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:06:48.932 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:06:49.683 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:06:49.683 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:06:49.683 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:06:49.683 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:06:49.683 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:06:49.683 WSACleanup called. | 2022-04-01 19:06:49.697 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:06:49.699 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:06:49.699 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:06:49.700 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:06:49.700 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:06:49.700 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:06:49.945 DTC Client socket (1) | Closed. | 2022-04-01 19:06:49.945 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:06:53.699 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:06:53.700 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:06:53.701 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:06:53.701 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:06:53.701 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:06:53.948 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:06:53.948 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:06:53.948 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:06:53.948 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:06:54.705 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:06:54.705 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:06:54.705 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:06:54.705 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:06:54.705 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:06:54.705 WSACleanup called. | 2022-04-01 19:06:54.741 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:06:54.742 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:06:54.742 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:06:54.742 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:06:54.742 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:06:54.743 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:06:54.990 DTC Client socket (1) | Closed. | 2022-04-01 19:06:54.990 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:06:58.745 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:06:58.746 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:06:58.747 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:06:58.747 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:06:58.747 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:06:58.994 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:06:58.994 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:06:58.994 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:06:58.994 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:06:59.739 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:06:59.739 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:06:59.739 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:06:59.739 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:06:59.739 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:06:59.739 WSACleanup called. | 2022-04-01 19:06:59.763 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:06:59.765 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:06:59.766 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:06:59.766 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:06:59.766 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:06:59.766 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:07:00.015 DTC Client socket (1) | Closed. | 2022-04-01 19:07:00.015 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:07:03.764 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:07:03.765 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:07:03.765 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:07:03.766 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:07:03.766 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:07:04.019 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:07:04.019 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:07:04.019 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:07:04.019 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:07:04.808 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:07:04.808 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:07:04.808 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:07:04.808 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:07:04.808 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:04.808 WSACleanup called. | 2022-04-01 19:07:04.822 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:07:04.823 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:07:04.823 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:07:04.823 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:07:04.824 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:04.824 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:07:05.073 DTC Client socket (1) | Closed. | 2022-04-01 19:07:05.073 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:07:08.819 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:07:08.820 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:07:08.820 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:07:08.820 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:07:08.820 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:07:09.070 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:07:09.070 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:07:09.071 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:07:09.071 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:07:09.834 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:07:09.834 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:07:09.834 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:07:09.834 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:07:09.834 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:09.834 WSACleanup called. | 2022-04-01 19:07:09.851 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:07:09.851 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:07:09.852 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:07:09.852 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:07:09.852 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:09.852 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:07:10.100 DTC Client socket (1) | Closed. | 2022-04-01 19:07:10.100 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:07:13.849 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:07:13.850 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:07:13.851 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:07:13.851 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:07:13.851 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:07:14.095 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:07:14.095 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:07:14.095 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:07:14.095 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:07:14.828 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:07:14.828 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:07:14.828 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:07:14.828 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:07:14.828 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:14.828 WSACleanup called. | 2022-04-01 19:07:14.832 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:07:14.833 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:07:14.833 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:07:14.833 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:07:14.833 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:14.833 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:07:15.074 DTC Client socket (1) | Closed. | 2022-04-01 19:07:15.074 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:07:18.836 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:07:18.837 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:07:18.837 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:07:18.838 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:07:18.838 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:07:19.084 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:07:19.084 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:07:19.085 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:07:19.085 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:07:19.853 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:07:19.853 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:07:19.853 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:07:19.853 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:07:19.853 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:19.853 WSACleanup called. | 2022-04-01 19:07:19.868 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:07:19.868 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:07:19.869 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:07:19.869 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:07:19.869 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:19.869 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:07:20.129 DTC Client socket (1) | Closed. | 2022-04-01 19:07:20.130 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:07:23.866 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:07:23.867 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:07:23.868 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:07:23.868 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:07:23.868 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:07:24.112 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:07:24.112 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:07:24.112 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:07:24.112 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:07:24.869 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:07:24.869 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:07:24.869 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:07:24.869 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:07:24.869 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:24.869 WSACleanup called. | 2022-04-01 19:07:24.883 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:07:24.884 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:07:24.884 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:07:24.885 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:24.885 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:07:24.885 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:07:25.134 DTC Client socket (1) | Closed. | 2022-04-01 19:07:25.134 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:07:28.887 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:07:28.888 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:07:28.889 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:07:28.889 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:07:28.889 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:07:29.135 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:07:29.136 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:07:29.136 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:07:29.136 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:07:29.902 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:07:29.902 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:07:29.902 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:07:29.902 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:07:29.902 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:29.902 WSACleanup called. | 2022-04-01 19:07:29.912 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:07:29.913 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:07:29.913 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:07:29.913 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:07:29.913 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:29.913 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:07:30.158 DTC Client socket (1) | Closed. | 2022-04-01 19:07:30.158 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:07:33.924 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:07:33.925 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:07:33.925 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:07:33.926 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:07:33.926 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:07:34.178 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:07:34.178 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:07:34.178 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:07:34.178 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:07:34.936 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:07:34.936 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:07:34.936 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:07:34.936 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:07:34.936 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:34.936 WSACleanup called. | 2022-04-01 19:07:34.951 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:07:34.951 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:07:34.952 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:07:34.952 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:07:34.952 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:34.952 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:07:35.206 DTC Client socket (1) | Closed. | 2022-04-01 19:07:35.206 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:07:38.946 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:07:38.947 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:07:38.948 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:07:38.948 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:07:38.948 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:07:39.196 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:07:39.196 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:07:39.196 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:07:39.196 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:07:39.958 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:07:39.958 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:07:39.958 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:07:39.958 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:07:39.958 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:39.958 WSACleanup called. | 2022-04-01 19:07:39.980 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:07:39.981 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:07:39.981 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:07:39.981 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:07:39.982 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:39.982 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:07:40.226 DTC Client socket (1) | Closed. | 2022-04-01 19:07:40.226 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:07:43.974 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:07:43.976 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:07:43.976 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:07:43.977 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:07:43.977 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:07:44.225 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:07:44.225 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:07:44.225 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:07:44.225 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:07:44.993 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:07:44.993 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:07:44.993 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:07:44.993 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:07:44.993 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:44.993 WSACleanup called. | 2022-04-01 19:07:45.012 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:07:45.012 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:07:45.013 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:07:45.013 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:07:45.013 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:45.013 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:07:45.264 DTC Client socket (1) | Closed. | 2022-04-01 19:07:45.264 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:07:49.014 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:07:49.015 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:07:49.016 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:07:49.016 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:07:49.016 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:07:49.271 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:07:49.271 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:07:49.271 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:07:49.271 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:07:50.018 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:07:50.018 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:07:50.018 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:07:50.018 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:07:50.018 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:50.018 WSACleanup called. | 2022-04-01 19:07:50.024 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:07:50.025 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:07:50.025 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:07:50.025 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:07:50.026 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:50.026 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:07:50.274 DTC Client socket (1) | Closed. | 2022-04-01 19:07:50.274 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:07:54.021 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:07:54.022 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:07:54.023 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:07:54.023 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:07:54.023 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:07:54.274 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:07:54.274 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:07:54.274 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:07:54.274 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:07:55.029 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:07:55.029 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:07:55.029 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:07:55.029 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:07:55.029 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:55.029 WSACleanup called. | 2022-04-01 19:07:55.035 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:07:55.036 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:07:55.037 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:07:55.037 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:07:55.037 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:07:55.037 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:07:55.288 DTC Client socket (1) | Closed. | 2022-04-01 19:07:55.289 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:07:59.047 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:07:59.048 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:07:59.048 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:07:59.048 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:07:59.048 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:07:59.540 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:07:59.540 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:07:59.540 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:07:59.540 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:08:00.341 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:08:00.341 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:08:00.341 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:08:00.341 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:08:00.341 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:08:00.341 WSACleanup called. | 2022-04-01 19:08:00.360 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:08:00.362 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:08:00.362 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:08:00.362 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:08:00.363 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:08:00.363 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:08:00.613 DTC Client socket (1) | Closed. | 2022-04-01 19:08:00.614 Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-04-01 19:08:04.370 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-04-01 19:08:04.371 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-04-01 19:08:04.372 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-04-01 19:08:04.372 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-04-01 19:08:04.372 Rithmic Direct - DTC | Network connection to server complete. | 2022-04-01 19:08:04.620 Rithmic Direct - DTC | Starting socket receive thread. | 2022-04-01 19:08:04.620 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-04-01 19:08:04.620 Rithmic Direct - DTC | Sending logon request message. | 2022-04-01 19:08:04.620 Rithmic Direct - DTC | Received logon response. | 2022-04-01 19:08:05.378 Rithmic Direct - DTC | Server Name: . | 2022-04-01 19:08:05.378 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-04-01 19:08:05.378 Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:08:05.378 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-01 19:08:05.378 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:08:05.378 WSACleanup called. | 2022-04-01 19:08:05.399 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-04-01 19:08:05.400 DTC Client socket (1) | CloseSocket call. | 2022-04-01 19:08:05.400 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-04-01 19:08:05.400 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:08:05.400 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-01 19:08:05.400 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-04-01 19:08:05.650 DTC Client socket (1) | Closed. | 2022-04-01 19:08:05.650 File >> Disconnect selected. | 2022-04-01 19:08:06.345 DTC Client socket (0) | CloseSocket call. | 2022-04-01 19:08:06.345 Rithmic Direct - DTC | Disconnected. | 2022-04-01 19:08:06.345 |
| [2022-04-02 12:06:18] |
This is the relevant error: Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-04-01 19:07:34.936 Regarding this, refer to: Rithmic Trading Platform Service: Permission Denied Resolution Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-02 12:07:16
| [2022-04-02 13:54:14] |
Can the account be with AMP as opposed to stage 5
| [2022-04-02 13:56:25] |
Yes.
| [2022-04-02 22:39:43] |
Well I don’t have an account as trying to pass an evaluation which means I cannot make use of the time you have given me to test
| [2022-04-03 00:19:39] |
If you want to be doing testing and evaluation of Sierra Chart, just simply use SC Data-All Services: https://www.sierrachart.com/index.php?page=doc/GettingStarted.php#ConnectingtoData Or the Simulated Futures Trading Service: Simulated Futures Trading Service No reason to be involving a broker at all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-03 00:20:02
| [2022-04-06 12:13:47] |
all my chartbooks from previous versions are no longer valid in this version
| [2022-04-06 12:14:47] |
For instructions to use them, refer to: Chartbooks (Workspaces): Opening Older Chartbooks (Bottom of the page) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-04-06 12:26:30] |
thankyou. So that i can trade in demo what data feed should i connect to? |
| [2022-04-06 12:48:50] |
There are two ways of doing this. You can use this service: Simulated Futures Trading Service Or follow the instructions below and use Trade Simulation Mode: Trade Simulation ---- To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-04-06 13:04:39] |
i tried that and for whatever reaso i cannot trade sim. It connects me as OUPTRIAL which i think in one up when all i want to do is have sim data to set up charts and DOM
| [2022-04-06 13:08:33] |
Follow the instructions below. And enable Trade >> Trade Simulation Mode On. ---- To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-04-06 13:11:36] |
service client does not support trade simulation mode
| [2022-04-06 13:31:59] |
What is "Global Settings >> Data/Trade Service Settings >> Current Selected Service" set to?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-07 13:28:03
