Date/Time: Mon, 10 Mar 2025 10:44:43 +0000
High and Lows from RTH chart and OHLC study do not align with ETH chart
View Count: 411
[2022-03-28 12:57:05]
User377189 - Posts: 209
I have attached a screenshot
Left chart is RTH chart and Right chart is ETH
RTH session
Start - 8:00:00
End - 15:00:00
ETH session
Start - 18:00:00
End - 17:00:00
I added Daily OHLC study on the RTH chart and this displays only the session High and Low
The session High and Low is different, you can see this on the ETH chart where the high and low is formed prior to RTH session ends but this is not captured on the RTH chart
Private File
[2022-03-28 16:33:45]
John - SC Support - Posts: 38516
We are not understanding the issue that you are trying to represent.
It sounds like you are wondering why the bar at 02:40:42 is not included in the RTH session's High and Low. If this is the case, then that is because that bar is not included in the RTH chart. You state that the Session Times for the RTH chart are 08:00:00 to 15:00:00.
The system will only calculate for the bars that are on the chart.
If this is something else, then please give us some additional information on where the issue is and how the charts are put together.
