Date/Time: Mon, 10 Mar 2025 14:35:50 +0000
Insert empty row on quoteboard not working
View Count: 651
[2022-03-28 11:33:30] |
YSS - Posts: 112 |
Documentation describes this functionality: Getting Quotes: Insert Rows when i right click there is no insert option or when i am standing on a line and I press INSERT key nothing happens I am running version 2376 please advise |
[2022-03-28 11:39:04] |
Where did you right-click? Make sure you right-click over existing symbols.
[2022-03-28 13:10:12] |
YSS - Posts: 112 |
Yes, it is over a symbol as shown in the screenshot
[2022-03-28 13:15:04] |
User90125 - Posts: 715 |
Same issue here as well. Using v2353 64-bit (40998M).
[2022-03-28 21:33:31] |
Sierra_Chart Engineering - Posts: 18727 |
Provide us a Chartbook with that Quote Board so we can test.
[2022-03-29 07:34:06] |
YSS - Posts: 112 |
See chartbook in attach, thanks for fixing
Private File |
[2022-03-30 08:08:58] |
Chartbook w/ Quote Board attached.
Private File |
[2022-03-31 19:59:37] |
Inserting is not supported when Quote Board column sorting is being used.
[2022-03-31 22:26:56] |
YSS - Posts: 112 |
Please update your documentation with this fact, also how to i disable sorting then
[2022-04-01 08:29:42] |
Documentation has been updated now.
