Date/Time: Mon, 10 Mar 2025 14:27:40 +0000
Requirements
View Count: 452
[2022-03-28 09:55:09] |
User577801 - Posts: 9 |
Hi, I have an account at AMP futures trading. I pay for the service package n°11 (Denali and market depth). I tried to connect my AMP account to Sierra and then to connect my Leeloo account (simulation account) but it doesn't work and I have the message (Symbol settings not found for current service". Can you help me? Thanks Maxime Cortes |
[2022-03-29 11:20:54] |
You need two installations of Sierra Chart: Using Multiple Data and Trading Services at the Same Time In each installation make sure you are using the correct symbols: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-29 11:21:02
