Date/Time: Mon, 10 Mar 2025 14:21:07 +0000
Petits Traits dans le DOM
View Count: 493
[2022-03-28 09:05:37]
User914407 - Posts: 49
Bonjour,
Comment enlever les petitts traits horizontaux qui représentent les volumes BID et ASK dans le DOM ?
Merci
[2022-03-28 15:50:15]
John - SC Support - Posts: 38516
From Google Translate:
How to remove the small horizontal lines that represent the BID and ASK volumes in the DOM?
Thank you
We believe you are referring to the following:
Trade Menu: Draw DOM Graph on Chart (Trade menu)
If it is something else, then please give us a screenshot of what you are seeing and tell us what we need to look for.
[2022-03-28 17:23:06]
Voivi une copie d'écran :
Private File
[2022-03-28 18:40:47]
That is the DOM Graph as we thought. Therefore, just go to Chart >> Chart Settings >> Market Depth >> Draw DOM Graph on Chart and set the option to No.
