Date/Time: Mon, 10 Mar 2025 10:31:21 +0000
SC Mistakenly Displaying Charts in Chartbooks From OTHER OPEN Chartbooks
View Count: 484
[2022-03-27 19:54:37] |
Halco - Posts: 92 |
When I have multiple chartbooks open and switch between them, say from Chartbook 1 to Chartbook 2, sometimes a chart or several charts from Chartbook 1 will display in Chartbook 2, even though they do not actually belong there. This chartbook "EUR CS" is supposed to have 8 charts - the EUR-X and the seven EUR pairs. You can see the chart in the upper-right is NZD-X from another open chartbook. Also under the menu CW, which you can't see, both the AUD-X and NZD-X from the other chartbook are listed as charts of this chartbook, which they are not supposed to be. https://www.sierrachart.com/image.php?Image=164841069976.png Date Time Of Last Edit: 2022-03-27 19:55:57
[2022-03-27 20:41:13] |
The reason for this, relates to this option: Window, CB and CW Menus: Window Always Visible (Window) Make sure it is disabled for those particular charts you have an issue with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-27 20:41:31
