Date/Time: Tue, 18 Feb 2025 22:40:05 +0000
AMP/TTnet . Problem connecting
View Count: 977
[2014-04-21 23:05:00] |
AC95765 - Posts: 1 |
Log: AMP/TTNet: Connecting. | 2014-04-22 02:56:58 Starting the Price Feed session. Connecting to 12.41.48.53 port 10501... | 2014-04-22 02:56:58 The network socket is connected. | 2014-04-22 02:56:58 TT FIX Data: Sending the Logon message. | 2014-04-22 02:56:58 TT FIX Data: Received a Logout message. Text = Unable to login to adapter AMPNON1ORPR: TTUserSetup Error - User has no gateways assigned. Please contact your System Administrator. | 2014-04-22 02:56:58 TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2014-04-22 02:56:58 Socket has been shutdown and closed. | 2014-04-22 02:56:58 TT FIX Data: Logged out and disconnected. | 2014-04-22 02:56:58 Disconnected from TT FIX Price Feed session. | 2014-04-22 02:56:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-22 02:56:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-22 02:56:58 AMP/TTNet: Disconnected. | 2014-04-22 02:56:59 |
[2014-04-22 00:07:06] |
Could you please contact your broker and let them know you are getting this message: TT FIX Data: Received a Logout message. Text = Unable to login to adapter AMPNON1ORPR: TTUserSetup Error - User has no gateways assigned. Please contact your System Administrator. | Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
