Date/Time: Mon, 10 Mar 2025 10:23:29 +0000
Left-aligned VbP Study Text Improperly Displayed
View Count: 520
[2022-03-27 06:55:34]
User272662 - Posts: 9
I have configured a VbP study to display delta on the left of my chart, however, some of the numbers are cut off. How do I change the padding?
Thank you!
imageDbPstudy.png / V - Attached On 2022-03-27 06:53:49 UTC - Size: 74.4 KB - 153 views
[2022-03-28 14:28:27]
John - SC Support - Posts: 38516
The only solution we can think of is to set the Input for Align Volume Numbers to Base of Volume Bars to Yes. Refer to the information here:
Volume By Price Study: Align Volume Numbers to Base of Volume Bars
Otherwise, we are not sure exactly how you have that setup, so we do not know what else to suggest.
[2022-03-28 15:07:31]
That works perfectly. Thank you!
