Date/Time: Mon, 10 Mar 2025 20:08:24 +0000
Option menus and border look
View Count: 705
[2022-03-26 22:49:35]
Jaydtrade - Posts: 88
I assure you I have looked for a ridiculous amount of time on my own before bringing this question here but I cannot seem to find the answer anywhere. A trader I follow platform with SC windows look like this. (see attached files) While mine are in the out of the box brand new look. I know this may seem minor but I would prefer the menus to look more modern and apparently they can so.. Any help would be appreciated.
imageSC Box Example.png / V - Attached On 2022-03-26 22:48:15 UTC - Size: 74.92 KB - 195 views
imageSC Box example 2.png / V - Attached On 2022-03-26 22:48:24 UTC - Size: 26.73 KB - 240 views
[2022-03-27 01:32:22]
In newer versions of Sierra Chart the General Settings window will look like this:
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=62827
We are continuing to organize all of the settings and categorize them better in that window.
[2022-04-12 10:15:41]
User824913 - Posts: 15
Sorry for the bluntness, but I think the standard menu was much better; writing a menu in white on black is difficult to read.
Furthermore, it is no coincidence that the classic menu chosen for years by all operating systems is easier to memorize and view.
[2022-04-12 12:46:26]
You can adjust the colors and behavior to exactly what you like!
You have full detailed control over these Settings Windows. Refer to:
Settings Windows Interface: Colors and Font Settings
And:
Settings Windows Interface: Changing User Interface Behavior
Make sure you are running an up-to-date version of Sierra Chart as there are ongoing improvements.:
Date Time Of Last Edit: 2022-04-12 12:46:56
