Date/Time: Mon, 10 Mar 2025 10:44:25 +0000
number bars + CQG + historical data = wrong volume at price - SC 2374
View Count: 561
[2022-03-26 04:21:07] |
Cavalry3162 - Posts: 523 |
when downloading historical data from cqg, sc's number bars show me totally wrong volumes at prices. it seems to be working correctly with live prices though. example see screenshot. please advise. |
[2022-03-28 13:33:39] |
John - SC Support - Posts: 38516 |
This would be related to how the historical data is coming into the system. Refer to the information in the second bullet point at this link: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2351 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-28 13:59:18] |
John, thank you.. regarding: "... Until you use the Denali Exchange Data Feed, you can go back to a prior version of Sierra Chart. You will need to re-download the historical data to obtain tick by tick data for up to 5 days. ...", do you happen to know what sc version suports cqg historical data? |
[2022-03-28 16:43:51] |
2348 and before should give you what you want.
