Date/Time: Mon, 10 Mar 2025 10:33:22 +0000
unable to manipulate one of my charts with the mouse (cursor), all others work.
View Count: 416
[2022-03-25 20:25:13]
User455351 - Posts: 1
for some reason I am unable to manipulate one of my charts with the mouse (cursor), any ideas as to what I did? Any idea why its only that one chart that I can't adjust?
[2022-03-25 20:42:53]
John - SC Support - Posts: 38516
Check what Tool is selected under the Tools menu. It may be set to something like "Adjust Regions" that isn't working as you expected.
[2022-03-25 20:51:52]
Tonkadad - Posts: 235
If you can't figure it out, the easiest thing to do is duplicate a working chart and delete the stuck chart.
