Date/Time: Fri, 04 Apr 2025 13:15:44 +0000
M6EM22 Issue
View Count: 593
[2022-03-25 15:06:41]
Yeager - Posts: 131
I can not get orders onto M6EM22_FUT_CME When using 'Use trade symbol as' on a 6e ladder or charts.
I can if the dom is only m6em22_fut_cme.
Have looked at symbol settings and historical chart symbol is resetting to MF?##
Strange.
I have noticed a lot of bugs with build 2372 since installing about 4 days ago.
Hlep would be appreciated and I have worked on this issue with Ian in Edge Clear already to no avail.
Best
T
[2022-03-25 15:20:04]
We are not aware of any issues. Specifically what?:
The problem you are having with M6EM22 is not a bug.
It is fully documented here and the very simple solution is provided:
Sierra Chart Teton Futures Order Routing: Using Trade Symbol
From documentation:
In the case of using the M6E futures contracts symbol, on a 6E futures chart, it is necessary to use the following settings in Chart >> Chart Settings:
Price Display Format: .00001
Tick Size: .0001
Trade and Current Quote Symbol Price Multiplier: 1
Documentation for these settings:
Chart Settings
Date Time Of Last Edit: 2022-03-25 15:20:30
[2022-03-25 18:14:49]
Yeager - Posts: 131
Great John.
Thank you for that. All fixed.
Have a great weekend.
T
[2023-01-03 19:44:34]
Yeager - Posts: 131
unfortunately the settings for M6E on Sierra Chart Teton Futures Order Routing: Using Trade Symbol are not working on my system for the last couple of weeks. The PNL Multiplier seems to be out of whack by a large number.
Can you let me know what settings to use?
attachmentm6e.jpeg - Attached On 2023-01-03 19:44:10 UTC - Size: 89.46 KB - 77 views
[2023-01-04 18:34:30]
Sierra_Chart Engineering - Posts: 19068
Make sure the Currency Value Per Tick setting is correct based upon the particular tick size you are using for M6E.
Date Time Of Last Edit: 2023-01-04 18:34:40
