Date/Time: Thu, 13 Mar 2025 10:55:49 +0000
Trying to Sign up for New Service
View Count: 612
[2022-03-25 02:19:40] |
CG - Posts: 1 |
I want to make sure I will be able to use the MBO with Nasdaq data. Which I believe I found the answer, and the answer is yes, as long as I had the correct feed, correct? I saw an update where it said the Denali Exchange Data Feed was now supporting the Nasdaq feed. So if I get the Service Package 12 will I have a real-time Nasdaq feed through the DEDF? Or will I have to add to my package a Nasdaq exchange feed?
[2022-03-25 14:06:44] |
John - SC Support - Posts: 38621 |
In order to get the NASDAQ TotalView data with the MBO information for U.S. Stocks, you would need to use the Denali Exchange Data Feed and enable the NASDAQ TotalView exchange. To do this, follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* Also, in order to get the MBO data, you will need to go through the following instructions as well: Market By Order Data: Step-by-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-13 11:55:10] |
Do you have any further questions about this or need any help? We would be happy to give you a new trial. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
